does anyone know where i can buy some replacement headlights
stock ones just new would be cool. Price????
Thanks for taking the time to post this info. I'll let you know how it works for me.xeon said:This subject has been covered more than once, but I will give you your answer since your post count seems to be pretty low, ie. you are new here. For less than $10 you can make you headlight look almost new. Just buy a pack of 1000 and 1500 wet/dry sand paper and have some rubbing compound or something handy. Get a piece of card board to put under the headlight and up the side of the headlight to prevent any "whoops, I didn't mean to do thats". I just cut a box top lid off a box I happened to have. Some people take their lights off, but I didn't see the need. Start off with the 1000 while spraying the headlight with water. I used a solution of Simple Green since it was in my spray bottle already made up. When you think the headlights are clearing up nicely, go to the 1500, then finish off with the rubbing compound. Finally hit it with some Windex and you should really notice a difference from one side to the other.
