link doesn't work?
I sure hope that when it comes to getting your KLZE etested, that you are doing it correctly. This applies to ANY vehicle on the road today that doesn't have the original stock motor in the car.you're saying the cop could tell it was a fake etest on the system? pleeeaase fix link cause when i need an etest there is no way my klze is passing![]()
Still ,they can't ask you to get one either.. If your car says it valid, then you DON"T have to get one.. Cops CAN'T make you spend your money just so they can see if it will pass or not.. I think your getting confused with environmentalist who can pull you over and if you have one single leak in your exhaust, they can pull it off the road.. They also have a portable sniffer they use right when they pull you over.... thats how they get you.ok lets re-phrase that to "If they wanted to or could send you" as a theoretical situation... that only would prove your car CURRENTLY either passes or fails which does not prove your previous pass was faked because something could have broke since the previous test.
That is all i am pointing out.
There is no fake test to be proven unless you are re-registering your cars out of the E-test duristiction and back which only proved you avoided the test not faked it.
