My heat isnt working. only #4 and i want to be able to use 1 2 3. i heard that 4 is a safty thing for everycar. I plan on going to the yard this week and i want to pick somthing up for the heat to work. Could i pocket this item? and where is it in the car. can you be exact, is it in the engine bay?
thanks for your help
Look under dash where to blower motor is located.
Behind the blower motor, there is a black plastic device that has 2 connectors on it.
Undo the connectors and then undo the screws that are holding it in.
Now when you remove it, you will see a circuit with wire coils on it. Thats the part you want.
Reactions: Maz25
