well I tryed to do the breather mod that is on performanceprobe.com to my 1986 mazda 626. Well I only did it to the part that goes back in to the intake side, and not the one from the PCV valve. And now it stalls unless you have your foot in the gas. I read about that this mod effects you oil pressure, but then I read that some ppl have absolutely no bad effects from it. So should I get some hose and fix what I broke or do I need to do it to the PCV valve side to get it to run again?:confused:
good thing I wasnt planing on going anywhere
You now have a big air leak... either plug the end of the pipe, or put it back to normal and you'll be fine.
John
yeah I was really stupid duh if there is air entering the intake after the VAF the ECU doesnt know it is going in
