Ok, yesterday i was rollin like any other day when i pulled into my friends house and shut off the car; then like 15 min later when i go back out and try to start it
it wont turn over (note it was about a 100 degree day out here in the southern idaho and the engine temp was about halfway between the thermometer symbol in the middle and the red dash)(by the way what could be causing the motor to get this hot, it has never gotten this hot and i know that if the motor gets real real hot in our cars the aluminum head could WARP or even CRACK) what is weird is ill let the motor cool off and then it still wont start. When i turn the ignition the motor doesnt start but you can hear the juices flowin. everything is fine all battery connections, good battery(normal amps on battery meter are shown) i have never had any problems like this before. i dont think it is the starter but maybee like the electrical to the starter because sometimes it does start like normal. there is something getting very hot and that i think is what is not letting the starter engage. could it be the computer failing or an old or wako thermostat, o2 sensor??? i just cant figure it out. what should i do???
I HATE PUSH STARTING THE DAMN THING!!!!
any help to get it to start every time like before would be way appreciated!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
