1 - 9 of 9 Posts
I just bought a 93 MX6 which i thought it was a good deal. Everything is working fine only with one major problem. The engine cuts out with RPM drops to the end when i am changing gear. Attempting to restart the car immediately is futile. But after a wait of 5 to 10 seconds the car can be restarted. I already replaced the spark plug but the problem still occurs. It is very dangerous for driving in the city. Anyone got the problem n solution??
Discussion Starter · #2 ·
the car is I2.0 i forget to mention. What i found from searching internet, some said it was caused by the distributor. Is it correct?
same problem happened to my 2.0, replaced the disty and everything was ok
Wasnt aware this problem existed on a 2.l ..but it is a problem on the 2.5V6('93-94 predominaltely).
The 'disty'- distributor components... IE the Ignitor, has been know to fail.. causing an immediate loss of power when under the gun/acceleration. Many have replaced the whole distributor.. but many, like me, have only replaced the ignitor in the disty/distributor. Thats my 1st prognosis.
****in' DISTY
I had the same **** happen to me. I am willing to bet your car has stopped running or will stop running very soon. I replaced my disty the first time and its really pretty easy, plus it saves alot
of cash. Get a Chiltons and a timing lite and someone who likes
to work on cars and your on your way to fixin that bull****. The install is easy just make sure you time it all. Ride on..
1 - 9 of 9 Posts
