hey there,
this all started shortly after i cleaned out my throttle body and installed a K&N air filter. the idle finally fell back to normal, but now when i'm on the gas (normall acceleration) in 2nd and 3rd gear the engine feels like it's missing or hesitating. not excessively but you can feel it. i've held the engine at 2000, 3000 and 4000 rpm in neutral and it doesn't sound like it's miss firing. so basically this only seems to happen when the engine is under load.
if anyone has any ideas please let me know. TPS? VAF? vacuum leak?(although my idle is OK), oxygen sensors?
i don't want to take it to the dealer just yet... $$$
thanks!
Hummm...
Did you try resetting the ECU?
Check your distributor and rotor?
Maybe a vacuum leak?
check it out won't cost you a thing... :)
