hey guys, i just got a set of tokico illuminas and i was wondering what stiffness settings u guys use with them. what setting would be equivilant to the tokico blues or stock shocks ?? im running ground controls with them. thanks guys
xeon said:
I think it is the 3 setting. Someone correct me if I am wrong.
Hey, if you like 3, go for it, there is no right or wrong answer.
I usually have my rears set 1 knotch stiffer than the front because the rear on the MX6 is a lot looser than the front. I usually keep them at 2 in the rear and 3 in the front. When you run the track, you want to keep the front end as stiff as possible to reduce wheel hop so I set the fronts to 1. Let me tell ya, with the ground controls all the way down and the illuminas set their stiffest, the car handels like a rock! I remember taking turns off the turnpike at like 65 in a 15mph turn. The car felt GREAT!
