LMFAO!!! the throttle cable is still attached to the TB? okay just pull on the cable so it doesnt rest in that groove, and slide the pin out.
Thanks Ill try that. Since my manifold off and
my rear valve cover i heard I should do phenolic
spacer, what are they ? and is there anything I
can do to the intake manifold to increase power?
theres a thread on that with a pretty good link thatll tell you everything. but basically, its a spacer that goes between your manifold and your head(s) and keeps the manifold heat down...
