Get the Light Through!
OK, here's what you do. Go to your local hardware store or Farm&Fleet or whatever and get some plexi-glass the same thickness of your old gauges. Cut out the plexi-glass in the same shape and stick 'em in instead of the old gauges with the white overlays on top. Then you can switch your bulbs to whatever color you want and you have an almost indiglo look. To get the cluster out of the car, you have to disconnect the tachometer cable from the doghouse of the car. It is located right by the firewall and has a coupler in the middle which you can screw off. When you get the cluster out, there are three screws on the bottom and three tabs which will allow you to remove the clear glass. GOOD LUCK!!!
