Help when i put my car on drive it dies or idles very roughly then dies All other gears work fine reverse nuteral park are fine its just when i put it into drive. Can anyone help me ??
Car is a 91 mazda mx6 lx auto
Ok, for the MILLIONTH time. Your throttle body intake tube probably has a hole in it. This is the big tube between the air filter and throttle body. If it has a hole anywhere in it, it can cause the car to run really crappy.
I think everyone with our older mx6's should replace these tubes as a precautionary measure when the cars get old.
if this is indeed your problem, try and fill it in with some type of RTV first. the mazda dealer wants like $40 for them. i filled mine with some and it worked like a champ. this is a quick and cheap fix. also if it turns out not to be the problem it didnt cost you anything but about 30 min of time and RTV.
Thanks
Thanks that tube had a hole in it and I bought a new one at the dealer for about 60 Canadian
Thanks again for that help you guys :')
