I just installed my Autometer boost gauge, but I am getting zero at idle and about 10 vac when cruising.
I heard I should be getting 15-20vac at idle. My boost seems to be alright, about 7-8 psi depending on the gear.
So which line should I be using? I used the one on the drivers side behind the throttle body, it has white dashes on it. I thought I should be using the one with green dashes, but can't find that one.
If anyone has a pic of where they tapped into for the gauge that would be great!
Any help would be appreciated!!
