my headlights are turning yellow on me, what can i do to clear them up, i heard u can use brake fluid, but i dont know if that would work, what else can i do?
If its not an Mx-6, it probably belongs in my toilet
healights
Hi,
There are many postings about this subject.
I used 1500 grit sandpaper on the outside of the headlights. Really work it until all the little scratches are out of it. You can even go with a higher grit sandpaper ie 1800. Then clean headlight. Get a spray can of clearcoat, they can be bought at most hardware or auto stores. Use even light coats, to keep it from running. Usually you wil use 4-5 coats. Spray until you see a crystal gloss. The outcome is incredible, your lighting will be brighter and they look better thenbrand new.
Headlights...
Search "sandpaper" in this forum you will get lots of info about the method mentioned above.
xeon
