Fuel filter would be a good place to start.
ahh ight thanks! i'll try that too xD. And yes i usually spend about 30-45 bucks a week. and my work is only 4 miles from my house lol!.Ok bud, I'm in the same exact boat, it's a typical '93-94 mx6 problem, they had a crappy distributor installed from the factory, they're $150 new on ebay and easy to install.
BUT before you do that, CHANGE THE O2 SENSORS!! They're most likely the reason, does it sputter when you hold the gas pedal down and sound like a 2-step launch control? My mx6 would blow black smoke while it was acting up. Don't drive it either unless you wanna spend 20 bucks a day on gas.
So it's either the o2 sensors or the distributor.
By the way (I should have asked before) is your check engine light on? You might want to check the codes: 1993-1995 Engine Controller Malfunction Codes
yeah. But imma try that again sometime when i get the time to put the bulb back in. I took it off when i had my car inspected lol.The check engine light comes on, but when you connect the ten and gnd pins in the diagnostic box, and turn the key to "on", the cel doesn't flash?? that is weird. Try again. Maybe the paper clip wasn't in properly.
Top picture: the thing with the black screw cap on top? That's your brake fluid reservoir. And it's low, and needs to be topped up (check you are not leaking brake fluid anywhere, if not, then it might just be low because your brake pads are a bit worn.
I don't know what that hose is. Where does the other end attach?
