I have two lights that stay on in my car. One is the "REAR" light is always on when my head lights are on. The other is "4w ABS" light. This light just turned on after I changed my shocks and springs. Anyone know anything about this?
Do you have an aftermarket alarm system? My rear trunk light stayed on 24/7 due to a malfunctioning part in my Clifford alarm.
With the ABS light were you super darfeul while working aroun the ABS cabels? You may have dmamged on or moved the sensor by accident causing one of the proxy sensors not to register. Check to make sure the sensors behind the wheel hubs are all ligned up correctly.
For the rear light, chances are that one of your bulbs are broken. Be aware that the MX-6's have TWO BULBS ON EACH SIDE, making it difficult to notices when a single bulb blows out. I had the same problem once. Hope that helps.
Related Threads
Mazda MX-6 Forum
2M posts
46.2K members
Since 2000
