1 - 16 of 16 Posts
well I have my motor built, I just need a oil pump to finish it. I ordered a toga HV oil pump from www.Importperformanceparts.com and I got the wrong one. The one I ordered was for for an 86 b2000. the one I needed was for a 95-02 Kia Fe-Dohc. When I went to order it from them, they said they were out of them and didn't know when they would be getting more. So I don't know if just a stock Kia pump would be good or where I can bring it to get it shimmed. Or if there is anyone else besides Toga that make a HV oil pump.
I think they are different.
On there website:
the part number for the 88-92 mx6 turbo is OPMA-12-HV
the part number for the 95-02 Kia Dohc is OPK4-HV
the only difference is the relief spring I believe. I have the one for a 2.2L turbo motor on my FE3 and have no trouble at 520whp. This is why I asked him if he had a relief spring out of an old FE3 or Kia pump. I used the Relief spring off one of my old FE3 pumps and shimmed it also.
can someone explain the word shim/ had it shimmed.
if possible a pic would be nice to clear things.
if not possible i will provide a pic since i have an oilpump in my garage which i took apart.
highly interested in this ..why buy a new pump if i can "shim" one.
:tup:
i believe the "shim" goes under the spring in the pressure relief valve part. purpose being more oil pressure before release/relief. the new pump will move more oil per crank rotation than the stock one. increasing the pressure will help force a little more through, but isnt a substitute for the extra cooling afforded by the higher volume pump.
Pics info on this 520whp fe3?
evo
evo
its a miata
I need someone to host the pics for me. As far as the motor here goes:
BLOCK
2.0 FE3 bored .020 over
Wiseco 8.5:1 pistons
Pauter Rods
Stock Crank
Toga High flow oil pump with shimmed relief spring
O-ringed block
HEAD
Port and Polish head
VR6 valve springs
Stock cams
SCE copper head gasket .043 thickness(I have part #s for these now)
TURBO
Full-Race T3/67
Spearco Intercooler
My custom turbo manifold
Greddy Profec Spec II
Greddy Type-H blow off valve
INTAKE
Custom sheetmetal intake
Infiniti q45 throttle body
PWR 92-00 Civic Radiator
DRIVETRAIN
Rx-7 turbo II tranny
Rx-7 Turbo II differential w/4:10 gears
ACT clutch 6-puck clutch
ACT Xtreme pressure plate
Fidanza light weight flywheel
BFGdragradials
Thats all I can remember right now. I use C-16 race gas which has a Motor octane of 118 I believe. I get by with using 110 gas now since I only run 15 degrees of timing at these power levels.
after having a look yesterday, the shield/cover on the left points towards the idler bearing, and the one on the right toward the water pump, so what i said earlier was wrong. they most probably are very very similar/same.
fred.
Discussion Starter · #13 ·
So what if I ordered a HV oil pump for the F2t ? could I just put it in or do I still have to change the spring? I still have my original kia/fe3 pump. the crank walked and scraped the oil pump.
you could test each pump with some sort of oil pressure source attached and a guage, and see what pressue they release at, then choose the most appropriate whether that be fe3 stock, f2t stock, or a little higher than those. i would think the stress on the f2t would be higher at 6k than the stock fe3 at 7.3k, but you never know.
I'll tell you what the difference between the two are. the F2T pump has a weaker relief spring because it doesnt have oil squirters under the pistons. The FE3 and Kia have oil squirters under the pistons therefore they have a stronger relief spring to make up for some pressure loss when the squirters open.
Discussion Starter · #16 ·
So you think there is a difference between a stock oil pump and a Toga HV besides the shim in the relief spring? I ordered a Toga HV pump for a 90 MX6 GT. Should be here in a week or so. I am going to take apart the factory pump and check it out. I'll take a few pics to.
1 - 16 of 16 Posts
