for some strange reason all of a sudden i noticed this. i turned on my a/c and inside the car you hear this hissing sound(you can hear it very well because the dashboard isn't on). it sounds like a vacuum hose or something sucking in air, but i wasn't aware of anything like that in the car. it only happens when the a/c is on though obviously. when you turn it on then you get this weird rattling/clicking from the engine bay, its very very fast, and this only happens at idle. if i give it gas it will stop.
WHAT THE HELL?
Does the hissing sound coincide with the moment the compressor engages? That's likely due to low refrigerant; the hissing coming from the evaporator.
Listen for the compressor rattling when it first comes on as well; the rattling you hear is likely the compressor. They are known to get loud when they start wearing, although it may still work perfectly fine.
Tyson
i was planning on changing the refrigerant out this weekend anyways, hope this has something to do with it.
Why were you going to change out the refrigerant? It doesn't exactly get old/bad like oil. Does the 94 have R-12 or R-134a?
The only reason you should mess with it is if it's low, and then you need to figure out why it's low.
Tyson
twas going to change out the refrigerant because i let some of it out when i changed my alternator on accident and it hasn't been real cold since.
the car came with a 134 system.
the moment you turn the a/c on the hissing starts and then the rattling, except like i said its not just a normal rattle its like a vibrating rattle its very fast. jsut started a couple days ago.
it does the same here
hi
i didnt notice the hissing noise but i definitelly hear that clicking noise when idle .... little step on the gas and it goes away .....
my a/c works great though ...
if yall gonna figure it out please post the cause of it .... and what needs to be done to get rid of it
thanks martin
ok here's the deal.
when the compressor is low on the oil it will start making that clicking sound. it turns out i had a leak(bad shrader(?spelling) valve so my low side leaked everything out. when i replaced it(with just a bicycle valve i might add) and refilled the system everything went away. i would check for leaks somewhere, add some stop leak oil stuff or something...
