I Just received my HKS Turbo Timer and I went to install it to the key switch connectors but the car has 2 female and 2 male connectors just like the harness and I cant figure out which plug goes where.
Here are is what I see in the car.
first connector, 2 wires(1st wire blue, 2nd wire blue w/white stipe) connecting to 2 wires(1st wire blue, 2nd wire blue w/red stripe)
second connector, 2 wires(1st wire black w/yellow stripe, 2nd wire white w/ red stripe) connecting to 2 wires(1st wire Black w/white stripe 2nd wire black)
Now on the harness from HKS.
3 wires going to 4 connectors
red-[12]volt constant
green-[12]volt ignition
blue-[12]volt accessory
the 4 connectors consist of 2 female plugs and 2 male.
only 2 of the plugs have the red wire(1 female and 1 male)
the other 2 plugs both have the blue wire(1 female and 1 male)
all the plugs have the green wire.
any help would be apreciated.:confused:
Plug the the end of the HKS harness with the blue wire on it to the ends on the car with the blue wire on it. I had to figure this out myself with the shop manual. You can also follow the wire to the ignition to figure this out. FYI the GReddy turbo timers plug into the HKS harness as well. I have a GReddy timer.
