a leak in fluid won't do it, but air will. our timing is electronicly controlled, well at idle. i don't believe that retarding or advancing the timing is going to do anything. i've never had to touch that. it sounds to me more like it still is the cap and rotor. i should've done it today but got too busy to do so. hopefully i'll get to it tomorrow. i've replaced cap and rotors before because of that reason and it worked out fine. just not sure bout mine that's all. i replaced it just last summer so i kinda doubt it but who know's.
AS for racingmazda's turbo kit, when you see it, you'll blow yourself. turbo is huge and i mean huge!!!! That TKT turbo is nothing compared to it. TKT has like a T04B housing, racingmazda has T04E. turbine is also like twice the size of TKT's. i know because i had a TKT, blew it up in one summer due to the fact that the damn factory wastegate won't hold it!!! and i compared it side to side. BIG BIG difference guys. exhaust manifold, the pipes or runners are even bigger than the exhaust ports on the head!!! i was impressed by it. he even makes a dump pipe for the wastegate to blow the hot air out below the motor!!! you won't see that a lot on external wastegates. intercooler pipes are nicely, beautifully bent and colorful (2.5in). gives you a HKS racing bov also. mounts and installs perfectly with no imperfection. intercooler fins are big also, 3 times the size of the stock one. he's coming out with one that's even bigger to. one that will take up the whole front end from headlight to headlight. that'll be awesome. his kit comes complete and you won't have to improvise anything to make it fit unlike TKT's. all and i mean all hardware comes with it, clamps,hose,fittings, all that you need to make it work. hopefully i figure out my problem soon so i can boost the hell out of it. he said i could too!!! turbo holds up to 450hp. i'm shooting 70 shot direct port nos into it and making it boost 20psi. see where i'm at now. he says at 8psi your running high 13's and at 16psi you're supposed to be at high 12's. so i'm guessing i should be like low 12's or high 11's with his kit. i'll let you guys know when i'm done with it.
