If you have the V6 engine they run hot due to the lack of space in the engine compartment. There are a few things you can try to lower the temp a little though. Flushing th radiator and adding Redline Water Wetter will help a bit. Ordering a set of phenolic spacers from Sean Morgan will help keep the intake manifold cooler longer. And adding a cold air intake will also help a bit. Not a lot else you can do past that point though.
