I just "degreased" my engine and apparently the washing has hosed the EGR sensor. (trouble code 16) Would someone please explain the process of cleaning it? Thanks!
More than likely the vac hose has come off your EGR, is loose or is cracked. Check for that first. You can pull off the EGR and clean it with carb cleaner/tb cleaner. Be sure not to get the sensor wet.
I took mine off today and it is chalk full of carbon. How easy is it to clean inside the head where the EGR is cause that's pretty nasty too.
