i need to replace the acc blower switch. how do i remove the dashboard panel (without braking it) so i can remove the switch?
are there hidden screws or is the pannel only clipped on?
i really hate to brake it...
ralf :sigh:
Remove the steering column housing (3 screws)
Remove the lower drivers side panel (2 screws at bottom) then clipped at top..
Remove the centre console... (clip at back of tray, under handbrake.. pull rearwards.)
Remove 4 screws from switch panel (one each side of steering wheel, at bottom, 2 under heater switches.)
pull away the switch panel, disconnecting the cables as you go.. and the vent cable.
The switch unit has 2 screws holding it in..
John
Reactions: ralfk
I do... so that's why it's easy :E
John
