This is a easy job, i have done it about 20 times in the last month, you will need a 10mm socket and a extention. take the corner out it might have a screw on the top. pull it from the place where the screw hole is and just pull untill it pops out, take the bulb out . the you will have to use the 10mm socket on the two bolts that you see to the right of the headlight (driver headlight) you can see them only if you take the corner out. there are only two of them so remove those and then just slide it to the side, the big screw on the other side the adj. screw !!
need any more help IM me on AOL!!!
