Hey guys i have a zex wet shot 65 shot setup that im installing and just wanted to know if i have to retard at all and if so how much? thanks
Ryan
Thats a good link with lots of good info but you didnt point out one very important fact.
You cant change the timing on a 2nd gen V6 car. As soon as you pull the jumper from the diagnostic terminal the ECU will re-set timing to whatever it's internal maps determine is correct.
You could turn the disty far enough to negate the ECU's ability to advance timing beyond a certain point but you would cause all kinds of problems.
