How to: EGR cleaning
well ive been wondering about how to clean/possably remove my EGR. and what kinda effects it may have on the engine if it is a removed and also what cleaning it can do. Also i keep reading post about erradic/jumpy idle. well after reading the post on MSP fourms Here all my questions were answered.
(below information is taken from the above post, i take no responsibality for the information contained )
_________________________________________________________________
A lot of people have complained about the eratic idle the Protege sometimes gets when the clutch is pushed in and rpms are allowed to fall quickly. The idle will jump anywhere from around 200-1100. This problem seems to get worse when the car warms up. My car started stalling everytime I pushed in the clutch or allowed it to idle. I had to feather it at stops like I was driving one of my old Vegas. Often people would think I was trying to race them because of the revving at the light. So I decided to do something about it.
1. The EGR is located directly below the throttlebody on the 2.0 engine. First remove the upper intake pipe (from IC on MSPs) and you will see it, it has a black circular cap and a grey six pin plug going into it.
http://www.msprotege.com/members/122%20Vega/DSC00155.JPG
2. The EGR is held on by two 12mm bolts that point up towards the throttlebody. Unplug the EGR and then remove these two bolts. The EGR will come right out. There is a thin metal gasket that may come out with the valve, or it may stay stuck to the mounting pad.
3. This is the valve out of the car. It consists of an electric solenoid attatched to a bypass valve.
http://www.msprotege.com/members/122%20Vega/DSC00157.JPG
4. Remove the four phillips head screws holding the electric solenoid from the valve body. This will come apart easily.
http://www.msprotege.com/members/122%20Vega/DSC00159.JPG
5. Clean the inside of the valve assembly completely with a carbon killer of your choice, I prefer Brake-Kleen. I was suprised at the amount of carbon build-up that came out of the valve.
6. Lube the shaft inside with a drop or two of oil and also lube the outside beneath the spring.
7. Reassembly is the reverse of removal. I suggest resetting the PCM while doing this, so the EGR can readjust after you start it.
8. You may want to follow the Manual's suggestion of measuring the resistance of the pins, but my car runs ten times better now, and I have no stalling issues anymore.
9. Time to complete, 30 minutes at most. Good luck.
-Britt
