* Orange is the clutch pedal
* Red is what you need to grease around
* Blue is the rod connecting with clutch pedal (where the screw is)
It's a crappy picture, but if you follow the clutch pedal, you'll see it hooked up through a screw with a cotter pin, I think. All you do is get some grease and apply some in between the screw and around the area, both sides front and back. When we push the pedal down, the shaft in blue wiggles (not the shaft itself, but where the end of the shaft meets with the clutch pedal) and rubs against the pedal causing the squeak.
As you can see in the picture, I just got grease crazy and greased everything until I found what the squeak was. I'm too lazy to clean up the excess grease though :)
might want to mention where is this located for those that dont know. Perhaps a picture that aint that close??? but either way, this must be good for those that have a squeaky clutch
