removing tint
It depends on if the tint is spray on or stick on.. I know that you can peel off the stick on but it leaves theat funky residue. Then just spray on some WD-40 and it will loosen that residue. you could also use GOO-GOne but that would take a little longer to work. As fas as spray on. Good question.
Spray some soapy water, and let in soak for awhile. Then use razor blade to scarp it off. (do this way for the front only) for rear windows, have professional do it becasue the defoger...
