1 - 15 of 15 Posts
I had to do this yesterday and I haven't seen a walk-through here about this. Granted, it's pretty simple, there's always a need for a how-to for some people!!
I had to do this because there was a slow oil leak near my filter, that would cover my filter in oil and drip off of the bottom. At first, I thought it was my OPSU. I replaced that, and it was still there. Next thing to replace: Oil Cooler O-Ring. Part # from Mazda: KL01-14-702A
Tools needed:
1/2" Drive Socket Wrench
30mm Deep-drive Thin-walled Socket (or you can do what I mention below)
5lb Rubber Mallet
Long Needle Nose Pliers
Step 1: Drain all of the oil out of your car, and remove the Oil Filter
Step 2: Remove the 2 coolant lines from the Oil Cooler. Be prepared, a LOT of coolant will start pouring out of the top coolant line. I just bent the hose upwards so the fluid didn't pour out.
Step 3: Remove the large nut where your Oil Filter normally goes. It's a 30mm nut, and you're going to need a thin-walled, deep-drive 30mm socket. Good luck finding one. I ended up buying a 30mm axle nut socket and filed off the top until it fit. It wasn't TOO bad, but it was a PITA.
Step 4: Once you get that nut off, you're going to realize that the 90 degree metal coolant nipple won't come out of that little housing surrounding the oil cooler. You can either remove the 3 bolts holding it to the block and remove the entire assembly, or you can do what I did. With my 5lb Rubber Mallet, i hit the shielding enough so it bent up-wards and allowed me to remove the oil cooler.
Step 5: There is an orange ring at the top of the oil cooler, this is what needs to be replaced. Pop it out, clean off the oil cooler (I used brake cleaner and a shop rag) and replace the o-ring. Coat it with a light coating of oil, just like you would your Oil Filter.
Step 6: Replace. Put the oil cooler back on, tighten up the nut and re-connect the coolant lines. Put your oil filter back on, make sure your drain plug is on tight, then fill with oil. 5qts with ZR-1 filter (WIX #51324) or I think it's 4.6 with normal filter. Check your coolant levels and re-fill if necessary. Start your car up and get back under your car to check for leaks.
For some reason after I finished this, my car started overheating on my test drive. I stopped at a gas station, checked for leaks and there were none. I drove it back home and it was perfectly fine. As well as the rest of the driving I did throughout the day, it never passed 1/2 on the Temperature Gauge. Odd...but whatever.
I didn't take pictures, but it's fairly simple to do without them.
Since I cannot find any mazda part numbers for the o ring, what exactly did you use for the gasket?
The part number for the O-ring (gasket) is KL01-14-702A. Cost is about $12 from Mazda. But yes, using the gasket off a regular oil filter does seem to work fine.
One tip: I found I didn't need to do step 2 above (remove the coolant lines). It was close, but the oil cooler will just come off with the coolant lines still attached.
Use a 10mm wrench to remove the two (not three) small bolts (yep, that step is a PITA).
Use very light torque when tightening that 30mm nut.
so is it really a 30mm nut? thanks for the part# :)
I'm not 100% sure it's 30mm, but it sounds right. I found I had an axle nut socket that fit perfectly, probably from doing the axles on a Tercel.
And you need to remove the splash shield as well, because otherwise access is very difficult.
But you don't really need to drain all the oil. You only lose the oil that is going to be lost when you replace the oil filter.
It's not a bad idea to replace the oil pressure switch at the same time, since that tends to leak too, and it's in the same place.
does anyone have a picture of this so called "oil cooler" i cant seem to find one
so called? lol
It's what your coil filter screws onto/into
I think the axle nut on the 2G is size 32mm. Since that 30mm nut is not torqued much, would the 32mm socket work to get it loose if you put a little stuffing inside the socket ?
It looks pretty simple. The water passes in and out, while the oil goes in and out of the oil filter.
The water pump is pretty simple mechanically too......if it weren't for leaks, they could probably last a very long time.
Just google "Ford Probe oil cooler" and it comes up.
I think I know what he's trying to get at...he things oil cooler and his mind goes all z0mg JdM 0il f00ler with finzzz!!!!
Ok thanks guys. Ive always seen that thing and wondered what it was Haha. So oil cooler, needed/useful for our cars? How about when turbo'd?
indeed it is. Oil is just as essential at keeping the engine cool as water is.
1 - 15 of 15 Posts
