I’m having some issues where when I have to blower motor installed, the control panel doesn’t send power to it. I took out the blower and hooked it up to the battery and it did work. I searched all over the place and found people talking about relays near the battery but I can’t tell which relay it is and they all look good. Any ideas? I looked on probetalk but that page is useless so I looked here. 1989 ford probe got
12971
The fuse closest to the rad is heater (yellow 40 amp).
In the dash fuse box the engine fuse should also be checked (15 amp).
The relay (on the mx6) is between the fuse box and battery in a rubber boot, about where your yellow harness wires are crimped and connected?
Also don't check for power going to the blower motor where you connected 12v, follow that connector/wires back and find the connector that goes to the resistor block under the blower motor.
The blue and red stripe wire should have 12v and the blue and black single connector wire should have 12V if they both do then the resistor bank need to be replaced.
