my 5th gear keeps poppen back into neutral whenever i shift into it. I didn't burn it out but i just need to get this fixed, cus its pissen me off. I would like to kno whether or not i need to buy a new transmission, or clutch, or a peice that would fix that for me. I also want to kno how much it would cost for me to get all of this work done. hit me back......
That would be a worn out shift fork for 5th gear. That means your transmission is messed up. It is a result of resting your hand (or the previous owner) on the shift knob. However, it can be fixed and is relatively easy, you dont even have to pull the transmission out. Do a search on the procedure. I have the parts you need to fix it, used but in good shape. PM me.
dex had the same problem and it turned out to be low tranny fluid check that frist.
