ok i have the angel eye headlights and everytime i try to put on the high beams i end up blowin the 40A fuse theyll work as low beams until i throw on the high then they blow completly except for the halos and parking lights cant find problem help:damnmad:
i would use a digital multi-meter and test for resistance to ground on the head light side of the fuseblock. assuming you find no continuity you could disable one head light at a time and see if the high beams work individually in order to isolate the problem. i would double check all wiring, specifically looking for any bare connections. they may not be directly grounding out, but could be arcing to ground under greater current draw.
