My stock shifter (from what I remember) had a slight bend in it, not a bad bend, and I'm sure it is possible that yours is bent too much. But a little bend is normal.
your shifter has scoliosis
I don't think that is right. THat bend seems too extreme. Does it fit in place? You might need to try and un-bend it and put it in place and see if it reaches. I'm pretty sure that isn't supposed to be that drastic of a bend.
It's probably not something the dealer would have. I would bring it back to the junk yard. Sometimes the junkies use hilos or bobcats to lift cars and the forks probably caught on it and bent it. I would bring it back since it's their problem and you should get a "new" good one.
