· Registered
I am buying a 93 Mx6 ls with v6 and manual transmission for 2900 with taxes hows that sound to all of u is that a reasonable price for one with 120,000 miles but in per condition it has new timing belt new wires n plugs n tires ...r these cars reliable?
· Registered
Search using the box located in the top right hand corner. It does wonders! :D
· Registered
Welcome to the board :)
There are a few problem areas, but compared to a 93 Cavalier yes they are quite reliable.
Distributor failure is an issue, hopefully yours has failed and been replaced by the updated Mitsubishi component by now.
Rear brake calipers are an issue....they tend to seize. Get remanned ones at every rear brake job if you can't get the updated ones.
The (mitsubishi) alternators suck :tdown:
Other than that, most of the little problems are aesthetic. Good luck!
-Garrett
