in this picture, can you tell me which 2 are the intake cams? Is this photo in the correct order of the cams or not?
If anyone happens to know the codes for each cam/where it goes that would be even sweeter.
thanks, i'll karma yo ass if you give me a good answer
edit: Also, on the two cams with the two piece gear, is it normal for the outside (smaller) gear's teeth not to line up with the bigger cog's teeth?
Yes, they are there to keep tension on the cams.
I don't remember the cams order up on top of my head, but you can tell by looking at them. Front bank cams has different ends than the rear bank, I think cams #451 has the slot for the disty, so you should know where that one goes. Intake cams for that head will look the same as the exhaust due to the single cams caps for the disty end. Two cams left and you can tell where they go by the cam pulley.
Reactions: cf_z
