1 - 20 of 22 Posts
my bro wants to gimme 1000 to spend on my car to make it go better,
whats the first performance mod i should do.
the exhaust or what ...
any ideas ???
thanks guys
i wish my brother would give me a grand :cry:
... i'll chip out now.
turbo back exhaust, and bleed valve (boost controller) and a Cold air intake
that should basically be ur 1k there, maybe $100 -200 or so left over.
to which goes to woos ecu
Reactions: Turbo626
Discussion Starter #6
how much would each of these cost ??
turbo back exhaust -
bleed valve (boost controller) -
Woos ecu -
ive gota CAI already.
also, would i need to get a turbo timer.. ??
ECU see here http://www.mx6.com/forums/showthread.php?t=130512
Boost Controller depends on what you choose - the for sale threads have seen them start from around $100 & a few manual ones new around $150 as I recall (mine is N/A so I will be corrected if I am wrong)
Exhaust do a search for "exhaust cost" or "exhaust how much" or simmilar. There have been a few questions very simmilar & so this will give you a good idea as to exact pricing
No one "needs" a turbo timer.
You just need to remember not to shut down for a minute or so after boosting.
how long do you cars leave your timers on for?
or sit in teh car for after driving? both whether you've given it a hard time and / or drive to the shops?
Well, I agree with most above. But I also think you might want to put away a couple of hundred to give your car a good tune. Especially if you haven't done it in awhile.
If I go for a drive without boosting at all (quite common) I only idle it for 10-15 secs before I turn it off...
When I go for a hardish drive, but driving slowly for the last 5-10kms, I usually idle it for 1-2 minutes... If I drive hard and then stop shortly after, I'll idle it for ages. :)
i got a turbosmart bleed valve you can have for $50 :)
but i would do
zorst
pod
bleed valve
cai
and change fluids and get a tune up :)
i can see he already has a CAI and pod in his sig.
u can get boost controller,s the turbosmarts or gfbs are common for under $50 second hand.
exhaust at a rough estimate, turbo back is about 800.
cat back about 500
woos ecu $200
First:
ALL fluids.
Oil Flush $15
Good quality oil $35
Oil Filter $10
Gearbox oil. $30
Brake and clutch fluid. $25
Try changing your powersteering fluid too. It'll feel better afterwards. $15
Ignition.
New plugs. Nothing beats the standard replacement one for cold starts, drivability, reliability. $16
New leads. Bosche is good awell priced. Don't forget the one from the coil to the dizzy. $50 for all five
Dizzy cap $7
Rotor arm $5
Cooing System:
System flush $35
Glycol/coolant $25
Braking stuff
New pads $120 for 2 pairs (front and rear)
$390 or there abouts. Your Car will go, stop, steer, run better than it does now. You'll be suprised.
What would I do next?
2.5" cat back exhaust. $350 is the going price round here. SE melb.
Woo's chip $200
Turbotech manual boost controller (These are the [shizzle] when it comes to manual boost controllers) $40 delivered
So all that take you to a grand sum of $980. Plus I would add $90 for a boost gauge.
For around about $1100, you can have a car that you will enjoy driving, as it goes hard, stops, steers, sounds and runs beautifully.
Now go do it and ENJOY :)
If your in Melb, Ilm willing to help you.
SABBAi said:
First:
ALL fluids.
Oil Flush $15
Oil Filter $10
Gearbox oil. $30
Ignition.
Dizzy cap $7
Rotor arm $5
Cooing System:
System flush $35
Glycol/coolant $25
Braking stuff
Woo's chip $200
id first add a compression test ;) see what state your motor is in before you go making it faster. if its rooted no point doing all this too it ;)
but then he can blow the motor and ask for some more cash from his brother to pay for a full rebuild =)
Turbo timers are waste of time. Most modern turbos have coolant flowing through them, only really old coil-cooled turbos need a turbo timer. Idle the car for 30-60 seconds and turn it off, or just drive gently for the last km or so before you get home :)
I do agree that a pressure test is worth while. It's something that should be done when buying a car. It gives you a very good indication on on the health of the engine.
There is point to maintaining a car though. Spending the money to get it running well, will pay you back in the long run. $400 or there abouts to get it in a good running condition isn't much.
1 - 20 of 22 Posts
