At one point CZT made a valve train kit that could supposibly handle 10,000 rpm. It was their stage 4. But only a couple were made due to the cost.
I'm guessing they're also making under 100wtq due to porting and really messing up the low RPM airflow.Chet96pgt said:The owner of PRM make 280 whp N.A out of a KL-03:tup: The way to make lots of whp out of the KL-03 is to port he crap out of the heads, cams and let her breath.
If you are talking about peak numbers, you are insane.Fastest95PGT said:I'm guessing they're also making under 100wtq due to porting and really messing up the low RPM airflow.
I'll admit I was exagerating. However, such a free flowing intake would dramatically hurt torque. The KL likes to run with fairly even numbers (whp/wtq) and every mod you do will change that slightly (ie: phenos and larger bore TB will tend to give more HP but lower peak torque).skiingman said:If you are talking about peak numbers, you are insane.
Piece of crap, eh? Do some research before making ill-judged statements like that :idea: Sounds like you don't understand exactly how pivotal the VRIS technology has been over the past 15 years or so, from impacting the LeMans RX, to the high-end Ferraris running around with variable length intake runners.Chet96pgt said:If an intake manifold is made right with ported heads and cams you will make large N.A HP gains. The 03 manifold is a peace of crap with the ZE being abit better.
Its not about "too much" or "too little" flow, its about the (inser term here....impedance may be most appropriate) matching between the IM and the atmosphere at a given frequency. Short, fat runners work the best at high rpm, the opposite for long skinny ones at low rpm.Fastest95PGT said:I'll admit I was exagerating. However, such a free flowing intake would dramatically hurt torque. The KL likes to run with fairly even numbers (whp/wtq) and every mod you do will change that slightly (ie: phenos and larger bore TB will tend to give more HP but lower peak torque).
A very free flowing intake (ITB's mounted right at the heads for example) would put a big hurt on the torque I would think by giving TOO MUCH air to the engine at the low end. Similar results to a 3" catback on our vehicle NA.
I'm just going buy someone whos built a 280whp KL-03, he told me in person the 03 manifold was a total bolt neck to making power after porting the heads.snailman153624 said:Piece of crap, eh? Do some research before making ill-judged statements like that :idea: Sounds like you don't understand exactly how pivotal the VRIS technology has been over the past 15 years or so, from impacting the LeMans RX, to the high-end Ferraris running around with variable length intake runners.
More whp then 280 with the stock 03 manifold N.A who?snailman153624 said:Being that many have gotten much more power out of it using the stock manifold, I'd say this person you're going "buy" is the "bolt neck."
No one has made 280whp with a NA KL....period.Chet96pgt said:More whp then 280 with the stock 03 manifold N.A who?
Dyno sheets aren't a timeslip :argue:skiingman said:dyno sheets or it didn't happen
