My first instincts would say yes as long as the plug pinouts are the same for the ECU quick disconnect plugs.
You may want to cross reference a wiring diagram for the plugs, and also check the physical plug shape to make sure it fits.
If it doesnt fit or the pinouts are diffrent you can always cut and splice the old harness to the new plug.
Your probablly going to have more luck over on a mx3 forum, I know this has been done before just not to much information on mx3 swaps on this website.
Edit- My post was thinking you were swapping the ECU out to a kl03 ecu. I dont think the KL01 will work with the 2.5L V6 Kl03
Again, Ryanpzz built the MS.
I cant remember the number on my stock ECU, but this is out of a probe fore sure KL85.
