Re: Instrument Panel/Cluster lightbulbs? 1993 Mazda MX-6 LS Coupe 2-Door 2.5L 2497CC V6 GAS DOHC Naturally Aspirated. VIN 1YVGE31B3P5175271. Several of the bulbs are out on the MX-6. I figured if I have to pull the cluster to replace a few bulbs, I might as well replace all the bulbs. I'm the original owner of the MX-6 and have never replaced any bulbs so 28 years use of the factory bulbs is probably pretty good. In any case, I'd prefer to get the bulbs before I pull the cluster. Looks to me that there might be as many as 28-30 individual bulbs to replace? Also, the probable size/watts might be different ... I'd guess 1.4w to 2.0w to 3.0w and the Trade Size likely 194LL and 73LL? Does anyone know for certain how many bulbs of what wattage and of what Trade Size the MX-6 has?
There is a sticky about all the bulbs in the 2G MX6 General forum
Thanks 'Goodbar.' That list will be helpful. One bulb (Fuel Level Warning) is listed in the Factory Manual as being 3.0 Watts ... would you know the Trade Number for that bulb? TMT
I believe this is what I used in my instrument panel:
My notes say:
env control panel lights (3) T-1 14V 1.4W bi-pin .05" (.2" max) spacing .38" H .165" (.2" max) diam​
JLK ENW1-EW10 14V .1A​
mini dash lights; T-1 1/2 wedge base .187" diam 0.693" tall​
Chicago Miniature Lighting​
CM286, CM1108; JKL ENW1-EW87​
large dash lights; stock: 158 14V 2CP (same as 194); upgrade: 168 14V 3CP 1500hrs​
T-3 1/4 14V 168​
brake light​
brake light 1157 12-14V .59A​
backup light​
backup light 1156 12-14V 2.1A​
parking lights​
parking lights 1157A​
trunk light​
trunk light: 194​
Ok, thank you for the info. I found 74LL and 158LL work for the instrument panel.TMT
