1 - 13 of 13 Posts
Hey guys/girls,
I have seen instructions on how to install a new intake for the mx6... but can someone who doesn't know a whole lot about engines really do it? Should I attempt it? Also, what are good brands? Lastly, will it make my magnaflow exhaust louder? :)
Thanks,
Alex
Discussion Starter #3
haven't purchased an intake yet
I haven't purchased an intake yet...
Alex
Discussion Starter #5
yes but....
What are good brands? where can I get a good price?
Alex
which engine do you have? its a lil bit harder with the 4 b/c the IAT sensor is located in the airbox
Discussion Starter #7
V6 2.5L
I've got the V6 2.5L
should be REALLY easy
Discussion Starter #9
so....
So... suggestions?!
i bought my filter for $15... just a plain jane cone filter. i feed it cold air with vacuum hoses. one blows the cold air at it and the other functions as a ram-air, forcing the air through the front element (its a dual element). its not really a true ram-air b/c i reach ATM and then air comes out of the larger element... but just that hose made it more peppy
Discussion Starter #11
Ok here we go
Ok, I think I have decided to just replace the stock box with a cone type filter. Do I need to worry about any sensors around/on the stock intake/or hose?
Thanks,
Alex
If you do this, you will actually loose hp because you are sucking in hot air from under the hood. I would either buy a cold air intake from http://www.hotshot.com or http://www.prmracing.com. Or if you are up to the task, you could make one for much less (mine only cost 50 bucks) http://www.geocities.com/adamk01452/MX-6_Intake.html
http://www.mtco.com/~westcj/Brian/k&n.htm
on the next site click on the how to page for the intake info.
http://www.acbservices.com/mx3gsr/
[Edited by MX-6 BOY jr on 04-26-2001 at 11:46 PM]
or you can do like i did...or go one step further... take a canister from an eclipse/talon, or other car that uses a cylindrical filter. attach it a feed it with turbo/vacuum hose. if youre really serious, insulate thermally and seal, giving you ram-air induction. you also wont have to worry about water ingestion like with the CAI option.
1 - 13 of 13 Posts
