41 - 55 of 55 Posts
What year of escape do i get the axles from? Im told there cheeper and stronger? I really need a set mine blew apart. And is there any other model i can get trany seals that match but is cheeper? Thanks guys
Sent from my GT-S5830D using AutoGuide.Com Free App
will the Fuel pressure regulator (or the fuel rail adapter for an AFPR) from a 2.0 fit the 2.5?
Fast but Safe (say WHAT?)
Does anyone know if the alt off of the millenia L will fit on the klde with as little modification as possible??
Sent from BLACK BETTY
The 2gen fuel pressure regulator from the V6 can be used on the I4 but there are slight differences ; The I4's Operating Pressure is 44 psi and the V6 is 45 psi . The fuel line ( nipple ) is clocked slightly different as well but it will work in a pinch .
I wanted to post this here as well since it is a go to sticky - The milly alt works but needs a extra power on wire hoked up and a small bracket .Very detailed instructions as well as other options are in the following links -
1.http://www.mx6.com/forums/2g-mx6-general/248622-alternator-replacement-stock-amperage-higher.html
2.http://www.mx6.com/forums/2g-mx6-general/248709-millenia-alternator-questions.html
Or the MX6 bracket can be modified to fit the milly alt... But be warned some major grinding involved if no torch is available
Administrator
If it's the alt that people have been using from the millenia, I think you need the alt and mounting bracket, along with the harness connector for the alt, because it has 3 wires. You have to run a third wire that has power with the key on.
Without a doubt you do need the three wire plug, but I was able to modify my MX6 bracket to accept the milly alt.
Hi,
Are 1993-1997 Ford Probe seats a direct fit in a 2nd gen MX6 ? I saw it is the case for 1st gen, but I wonder for 2nd gen.
Hi,
Yes, 2g seats can work in either Probe or MX-6. More often, people run MX-6 seats on their Probe as they are more comfortable and look better.
Thanks for the reply. Actually, I'm not willing to swap genuine seats, but I can use this information when looking for aftermarket seat brackets for my MX6: Probe brackets will fit as well, and I believe they are easier to find.
41 - 55 of 55 Posts
