Well, I killed 2 birds with one stone today......
It smelled kinda musty [in my trunk] when I was bringing some groceries in today, so I lifted the carpet up and it was all wet underneath...... I know this is a common prob with these cars...
I pulled EVERYTHING out, dried it out, cleaned it all with "greased lightning" cleaner, and then I used some silicone sealer to seal the spots where I could see light coming through.....
My spare was low on air, filled that... the "rattle" i thought was coming from my R/R shock tower was my jack, which is rusted shut (not a single spot of rust in the trunk, except for the jack) and it snapped when I tried to get it to move....so I need a new (used) one of those... THat was what was rattling...
So, just to verify, the "holes" on the sides of the trunk I sealed, and also I sealed around the "rubber plugs" on the bottom area, around where the tire normally sits.... I could see light coming from these areas, so they're all sealed up now... any other spots you'd recommend I seal up while I'm in there?
There's no rattle when I go over bumps anymore!!! woohoo! (It's a relief when you're in your car for 2+ hours a day...
