1 - 14 of 14 Posts
The lights that are in the door and also on the roof all don't work, the aerial doesn't go up either when i turn the radio on. Also, the car doesn't make that beeping noise when the car door is open, only when the car is turned on does that noise come on.
I have checked the fuses and none of them are blown (thorough check).
Someone please help!
Did you check the fuses with a test light or taking em out one by one? one of my friends had a similar problem he said he check em all then i check the fuses with a test light bingo.
check ur fuse box and replace the "radio" fuse keeloh knows what he's talking about.
Maybe the door switches are bad?
hmm i'm not familiar with the 2nd gen fuse box, do you think it might be the "audio" fuse?
did u find out what the problem was? maybe a harness clip is damaged somewhere. not making contact or something, it's gonna be hard to know unless u take ur time with it.
If fuses all check out, and door pins check out then look at the timer control unit. It's responsible for the slow dimming of the lights after you close the doors. It's right above the interior fuse box, by your left foot as you drive. Hard to get to, but sometimes that box gets blown before the fuse does, happened to me.
1 - 14 of 14 Posts
