1996 MX-6 LS
V6 MYSTERE SERIES
OK, HERE'S THE STORY...
I WAS GOING DOWN THE FREEWAY ABOUT 80 MPH AND SUDDENLY Sa' Les STARTS LOOSING POWER AND THE SOUND OF HER PERR CHANGES TO A MUFFLED GURGLE. I THEN DOWN SHIFT TO 4TH AND SHE TRIES TO GAIN BUT THE NOISE GETS WORSE, SO I GO BACK TO 5TH. THEN SHE HANGS ON FOR A WHILE AND _______________, THERE IT IS, SHE FLAT LINES. MEANING THE CAR SHUTS OFF AND WON'T RESTART, SO I LET HER KEEP COASTING UNTIL WE COME TO A STOP. I POP HER HOOD AND SMELL A FAINT SMELL OF BURNED RUBBER, BUT NOT SOMETHING THAT YOU WOULD SMELL IF YOU WEREN'T TRYING TO SMELL ANYTHING. OTHER THEN THAT ALL OF THE WIRING APPEAR TO BE GOOD, ALONG WITH THE HEADS AND EVERYTHING ELSE THAT'S EXPOSED UNDER THE HOOD. SOMETHING SAYS, "KELLY, CHECK THE OIL." SO, I CHECK THE OIL, THE DIP STICK IS BONE DRY. I PULL THE OIL PLUG OUT WITH MY CHANGE KIT THAT I KEEP IN THE TRUNK, 4.5 QTS CAME OUT, SO I KNOW I HAD OIL. I HAVE THE CAR TOWED TO MY HOUSE AND I ADD 4.5 QTS OF OIL, I STILL GET A DRY DIP STICK NOW, AND THE CAR HAS NEVER STARTED SINCE, ALL I HEAR IS THE STARTER CLICKING, BUT NOT ONCE WILL YOU HEAR THE ENGINE ATTEMPT TO TURN OVER. DOES ANYONE HAVE ANY INSIGHT THAT CAN HELP ME OUT, OR HAS ANYONE EXPIERIANCED THE SAME THING?
1996 MX-6 LS
V6 MYSTERE SERIES
