1 - 20 of 47 Posts
The Telstar that can Nevah lose is back!!
Now fitted with:
Custom manifold with T3 flange.
T3 with 2.5" to 3" dump.
2" cooler piping.
2" AFM to turbo pipe.
Supra Cooler.
5th Injector.
Rebuilt top end.
twin fuel filters.
Front strut brace
SSQV BOV
Sierra Cosworth bonnet vents
A few other bits and pieces here and there. pics tomorrow!
It's ALIVE!!! You must of worked hard over the weekend hehe
How does it go with the bigger turbo?
Interested in pics, can't wait either :)
You know that sounds familiar to my car...
Custom manifold with T3 flange. I have a dodgy adapter plate :)
T3 with 2.5" to 3" dump. - Same
2" cooler piping. - Same
2" AFM to turbo pipe. - Same
Supra Cooler. - Used to have, now 600x300x76mm
5th Injector. - No...
Rebuilt top end. - Same
twin fuel filters. - No...
Front strut brace - No
SSQV BOV - Vee port
Sierra Cosworth bonnet vents - I've got 1, you have 2?
Should go well, I dynod 200hp ATW on 12psi.
sweet sabbai Ill come check it out on the weekend if ya free glad its all up and runnign again..now what are you gonna do with that spare turbo :)
with all that work donen its just missing one thing, aftermarket management :p
good stuff tho :-D
Discussion Starter #7
The bonnet vents are genuine Sierra Cosworth ones. A mate of mine was importing stuff for his Cosworth Saphirre and I asked him to find me a pair. $90 shipped. Better than paying $100 for fibre glass ones plus shipping.
AS for power, going by G-tech on the previous setup, and I know they aren't supper accurate, I managed a 0 - 60mph in 7.34, which equates to 203.4hp atw. How accurate that is, I'm not sure.
I'm going to drive around in it for a while and probably go for a UNIchip or some other piggy back.
Next thing is to take it to the exhaust shop to fix parts of the manifold, and also bend up the midsection.
I'm going to keep all my stock parts at this time. just to cover my arse from Mr Plod.
i would suggest going standalone, but leaving the stock ecu in there, just take off the injectors and hte ignitor module trigger wire, simple fact is you have a lot more controlability.
Discussion Starter #10
That's an interesting point you have there Mark.
Crusty, I took the car for a gentle spin today. 6psi. Partial throttle, feels kinda like it did on 12psi.
It appeared to be very hot. I adjusted base timing to 9deg btdc. it seemed to jump around between 6 and 10. My temp guage doesn't seem to be working though, so that's another thing before I drive it properley. That and an A/F gauge at least.
saw this car today... engione bay looks the goods...
btw Scott, did you have any bits lying around i might be intesrested in? or you dont need anymore?
im looking for the exhaust manifold shield...
Discussion Starter #13
im keeping an exhaust shield, as i want to make it look standard.
in case u forgot, ur timing belt covers still off
No complaints here
Like to see what it pulls up on a dyno
Discussion Starter #19
The exhaust out the side is track days only. With the stock setup, I gain 3psi, upto 15. It removes the cat then 1 resonator and out the side. Best $120 I spend performance wise. It doesn't stay on the car. Just never removed it from my last track day. It's been off the road since then.
Muppet, haven't put it on yet to make sure I wasn't a tooth off for the timing.
Jords, the welding is craphouse, but it's going to the exhaust place to fix this up and make up the 3" midpipe.
i got 2.5inch with one resonator where cat is, and a cannon on the end :p i love loud exhausts :p
109.1 decibals :) louder then most people's stereo's
1 - 20 of 47 Posts
