Id be interested in the rear rack depending on the price....if its the same as the mx6 4ws (assume it is). Id grab everything related to it if i were you (P/S sensor, trans speed sensor, control unit, secondary fuel pump control,etc.)
I've already got all that stuff from other better candidates previously.Id be interested in the rear rack depending on the price....if its the same as the mx6 4ws (assume it is). Id grab everything related to it if i were you (P/S sensor, trans speed sensor, control unit, secondary fuel pump control,etc.)
shawweeet.Computnut21 i will check on the rubber steering part you want but i will assume it is busted, too.
Yeah the pricks at my local junkyards do the same. Bastards.:tdown: The one I stripped all my parts off of had one that was in good condition tooAnd defiler, this JY punctures all tanks so this one is no good to anyone.
ok, you can remove the flame suit. I got it all out of my system in that other thread. It is a jealously thing....nothing personal. No need to beat a dead horse.If its in decent looking shape, then id like to hve it as a spare, along with the other stuff...
And lets not turn this into another flame thread...Ive already shown the subframes are the same, proving they will bolt in, and im working on the wiring today....the two things that were said to be impossible....so lets keep the "it cant be done" to ourselves
If you want to make some spare cash, we can work a deal...if you want to flame me (agian) ill pass...thanks
Dude, it's called "The MAzda Dealership". They can get you any part for these cars still (Other than the fucking gas tankand like everything else on the 4ws system its impossible to find parts for.
Yeah that person was a moron, seriously. For all the work they did, I dont know why they wouldnt have just removed the shaft instead of cutting it. Must have been they were saw-happy, since they also cut thru the thickass parts of the front tie bar to remove itI DO currently have a spare rear rack, for parts. All parts are good on it, except where the dolt who used to own that 4ws mx that defiler now owns, cut the shaft out from the back even so he could put in a regualr gas tank.
Well... you've proven they look the same, but not yet that they will bolt in....Ive already shown the subframes are the same, proving they will bolt in
You can send it here and I'll test itSo Jeff, is there any way to test those units off the car, or is it just swap in the unit on the car to test? There was someone who wanted to buy my spare one on here, but I never have gotten the time to test it in-car (and now that the 4ws is disabkled, I suppose there is no way to test it yet)
i snagged the timer unit you speak of...i will test it this afternoon or early evening after i get back from the movies. headed out to see "burn after reading."i need the box thats under the passenger seat. anybody got a spare that they know is working i could purchase? id sure appreciate it. thx in advance-
I was actually asking how to test the control box/timer units. The rear rack isnt a problem; even if it is bad, racks can be repaired. BEcause I think 4wsgt was the one I needed to test this for... (I just found it again in the attic too)You can send it here and I'll test it j/k that would be a ton of work. these rear racks are built well and minus the inner shaft breaking on some AU's car, 19/20 problems with the 4ws are the timer unit under the passenger seat or something electrical.
You could test resistance of the stepper motor, visually inspect the condition of the hydro lines on top (i have replaced a set in every 4ws rack i installed) of the rack, and if you were so inclined you could pop out the 4ws hydraulic filter and see how dirty/inspect for shavings.
I would be more worried about purchasing a bum timer unit then a bum rear rack.
