These Mounts are made with Prothane Solid Polyurethane Bushings, Poly Sealed inside the mount.
Included is 1/2in Hardware and a pre-anti seized sleeve.
Details:
This mount is a direct replacement for the passenger side motor mount on the KL03/DE/ZE Motors
found in the Mazda Mx6, 626, Mx3 and Ford Probe.
Provided is a ½ Bolt to take up any slop that might have been worn into the mount bracket.
A small amount of dremeling may be needed to widen the bolt hole on the bracket if yours is not wore.
Using the stock bolt will work, however it will not be a tight fit in the new poly mount.
Benefits:
Reduce engine movement
Tighter shifting
Replaces weak/expensive stock mount
Custom look.
Right now I have 3 of these on hand.
Primer coated (black or grey),
Ill leave it up to the buyer to paint them.
However they will need to be taped off since the bushings are not removable.
These are a K6F custom, to date I have not seen any vendor offer anything like these.
Canada buyers PM me with zip for extra shipping $.
All Items will be shipped the following Monday or Friday, depending on the when the payment is received.
I have a limited quantity of parts on hand, therefore allow up to 7 business days after payment for fabrication.
Terms:
These are basic parts for the mx6, all sales will be final, no returns.
Warranty on parts from defects of craftsmanship 30days from purchase date( excluding finish), should your part fail, please contact me through pm.
No warranty on custom order parts.
Buyer is responsible for the installation and use of these parts.
How hard is it to install this mount? Can I install it in my driveway without moving the motor? I may be your first customer if I can do it in my driveway with basic tools.
I did it in my drive way with a jack, a 17mm deep well socket, extension and ratchet in 5min. Also 2- 3/4 wrench's for the new bolt.
Basically:
park car->pop hood-> place jack under oil pan with wood block -> jack the motor up a little bit-> remove the 2 nuts on the mount, and remove the side bolt. Make sure new bolt will slide into the cradle, if it doesnt..file/dremel out the hole a bit. ->bolt in new mount.
All 3 sold, quicker then I had thought they would..
Ill have them all out this week:tup:
Ill leave this up since I am capable of making more, however I need to order more materials, May need to require a downpayment for those seariously interested.
I would like to get one. I can have the money by this Friday. Also King, since I am here is there any update on the subframe connectors? Are you still updated the design or are you pretty set? I am also interested in a set of the connectors.
Hey I thought you were going to tell me when you were doing this again so I could own two lol. (Damn now were not the only ones with them lol) I got the MX6 back but I need one for the Probe now.
You ready for me to buy those things I asked you for yet? I am ready.
