· Registered
1st thing, let me stress to you that I do not know if the MX-6 is programmed the same way a Probe is.
2nd thing; Here is how it's done on a Probe. I typed in the instructions from the '94 shop manual for a Probe.
Barry
· Registered
ahh yeah thanks but that is not the way mx6's are done.. its actually prety simple it was said in the 2g forum under projects sub forum.... simply put the key in and on position, take it back out, and place it in again another 2 times the same way.. then press that little button that closes the dome light when the door is open 3 times.. then the car chimes once.. and u just press the lock button on each keyless entry transmitter twice for each one and wait for the car to chime after it.. then wait 15 seconds and the car chimes 4 times telling you it locked in the new codes programmed.. however in this diagnosis mode it erases all memory too, so you need to reprogram each one you have.:D
