I'll admit I didn't dig too deep to see if there was a thread already on it but my 1993 DE sounds like it spun a rod bearing.
Taking it out soon and checking everything, seeing if it'd be easier just to rebuild than to swap the ZE in.
Just wondering about tips or if it's possible to just direct fit it. Or even possible to swap just the internals and get everything for that done.
Thank you for the help everyone.
The KLZE is a direct fit.
You might possibly need to swap the part just under the coolant filler cap (forgotten what it's called) because your 93 is different, since it has the extra coolant temperature sensor that controls the fans.
And I'm trying to remember if you need to swap something for the EGR valve.
But it's very straightforward.
And welcome to the board! (Not many of us left nowadays.)
This looks like a good thread. (There are many others, mostly in the "Other performance" section.)
Discussion Starter #4
Ok awesome I appreciate it I actually ended up buying an automatic DE and I'm just going to try to get that to fit for rn.
But no worries I've been thinking about getting a ZE sooner or later and building it out of the car just so I can have more ease with it and it won't take up as much room.
Discussion Starter #5
If you have any tips or ideas on how to make this automatic engine work with my manual transmission, then I am seriously all ears. In process of taking the old engine out to assess the damage and see if it's savable
