Hello all. Anyone has a "binary file" of the KL03 or KLZE ECU PROM?
I got a KLZE engine, but without the ECU, so I plan to plug-in the
KL PROM into my KF ECU, so I can run the KLZE properly.
Please email me the file if you have a copy.
Thank You,
[email protected]
What year car/PCM is this intended for? Compare your PCM hardware to that shown on my webpage under "PCME". If it's identical in appearance, I can send you a copy of some '03 code.
Be aware that there were a couple of hardware revisions made to the PCMs that mean that not all versions of firmware are compatible with all hardware levels.
Discussion Starter #3
Hi Mike. Thank you for your reply. My car is '94 626 with KF
engine. The PCME look identical to the one on your webpage
(btw, you have a *GREAT* webpage!). I am not sure about
its revision tough. I really appreciate if you can send me the
03 PROM image, so I could give a try on my new KLZE.
I am also into microcontroller, so I wish I could do
some reverse engineering on the PCME like you did
someday :).
Best Regards,
[email protected]
I have all sorts of EPROM bin files.
I have 93 and 94 PGT data
I have 94 ZE
I have 92 Telstar ZE
I have 92/93 K08 Mx3
and I have another 626 bin file
i also have a ZE with 03 VAF tables but for some reason it will not work in any of my 3 ECM's.
www.cybertekguy.com
drop me a line
Steve
Discussion Starter #5
Hi Steve, I live on the other side of the planet, so it is
a bit difficult to drop you a line.
Mike 94PGT sent me a copy of the Kl03 PROM. Thanks Mike for the file!
Anyway, it will be great :D if you could email me a copy of
the KLZE EPROM on my KF ECM, so I could do some comparison
between the KL03, KLZE, and my original KF EPROM.
Regards,
[email protected]
Kuala Lumpur, Malaysia
Discussion Starter #6
Thanks to Mike and Steve for sending me the PROM file.
I got more than I need, and that is great! My KLZE will
be fire-up tomorrow and I can't wait! However, it will
still be using the KF PROM until later. My mechanic said
the KLZE perfectly matched the KF, except the KF drive
shaft is seem a little smaller for the KL CV joint (engine side).
Regards,
omar
