Until I can locate the proper manifold, I have been using the stock KLD IM on the ZE engine and have been fighting vacuum leaks (due to the different port sizes?).
Has anybody had luck with any particular method of sealing? I have tried silicone (2x) and most recently cut my own gasket to match the ZE "O.D." and the KLD "I.D." - still no luck.
I will disassemble again tonight and check the vacuum chambers as well, but leak is confirmed around IM flange using carb cleaner when engine is running.
Thanks!!
Thanks!!
